The new KENWOOD TH-D72 handheld offers many APRS functions in a small unit. One proplem is, that users which are new to APRS often do not adequately configure their radio. That's why I offer you my settings. Important settings for a good working APRS network are in BOLD.
Новый KENWOOD карманный компьютер TH-D72 предлагает много функций APRS в одном флаконе. Одина из что пользователи, которые плохо знакомы с APRS часто, не соответственно формируют свое радио. Именно поэтому я предлагаю Вам свои параметры настройки. Важные параметры настройки для хорошей работы сеть APRS находятся в BOLD
| menu # | menu | command # | command | setting | comment |
| 11 | Battery | 110 | Battery Saver | 0.03sec | Important! With other settings the chance is high to miss incoming packets because your radio is sleeping. |
| 30 | Basic Set | 300 | My Callsign | DL8RCB-7 | Change to your callsign. Use SSID -7 to identify a human portable message capable station. |
| 301 | Beacon Type | APRS | We want to do APRS with the radio. | ||
| 302 | APRS Lock | ON | Set this to on after having the right APRS frequency (144.800 for Europe). | ||
| 31 | Int. TNC1 | 310 | Data Band | A-Band | APRS will function on the A-Band |
| 311 | Data Speed | 1200 bps | APRS data will be sent and received at 1200 baud | ||
| 32 | Int. TNC2 | 320 | DCD Sense | D or RxD Band | |
| 321 | TX delay | 150 ms | |||
| 33 | COM Port | settings are irrelevant for standard APRS | |||
| 34 | Waypoint | settings are irrelevant for standard APRS | |||
| 35 | PC Port | settings are irrelevant for standard APRS | |||
| 36 | My Position | Enter your position. This postition will be sent, when the internal GPS is switched off and BCON is pressed. | |||
| 37 | Beacon Info | 370 | Speed | ON | Your speed is sent in position reports. Set to OFF if you drive excessively fast. |
| 371 | Altitude | ON | Your altitude is sent in position reports. | ||
| 372 | Pos. Ambiguity | OFF | There is no reason to put errors in your position report. | ||
| 38 | Comment | 381 | Position Comment | Enroute | Choose a comment describing your current activity. Don't use EMERGENCY! unless there is a real emergency! |
| 39 | Status Text | 390 | Rate | OFF | Don't use a status text to keep your packets short. Use one if there is a special reason. |
| 3A | QSY (FREQ) | 3A0 | QSY in status | OFF | Set to ON if you want to tell others on which VOICE frequency you are working on the B-Band. |
| 3A1 | Tone/Narrow | OFF | |||
| 3A2 | Shift/Offset | OFF | |||
| 3B | Pkt.Filter | 3B0 | Position Limit | OFF | Set to ON if you want to limit data you receive |
| 3B1 | Filter type | An ASTERIX (*) should be seen for all the options. Delete the ASTERIX with MHZ for the type of stations you do not want to display. | |||
| 3C | Icon | 3C0 | Person | Choose an appropriate icon four your current activity. Don't use fancy icons when there is no special need to do so. | |
| 3D | TX Beacon | 3D0 | Method | SmartBeaconing | |
| 3D1 | Initial Interval | 5 min | |||
| 3E | Algorithm | 3E0 | Decay Algorithm | OFF | Doesn't make sense to set it to ON for low power portable. |
| 3E1 | Prop. Pathing | OFF | Doesn't make sense to set it to ON for low power portable. | ||
| 3F | SmartBcon1 | 3F0 | Low/High Speed | 3 - 50 km/h | |
| 3F1 | Slow Rate | 15 min | When not moving you will TX a postition report every 15 minutes. | ||
| 3F2 | Fast Rate | 90 sec | When moving above 50 km/h you will TX a postion report every 90 seconds | ||
| 3G | SmartBcon2 | 3G0 | Turn Angle | 28 deg | |
| 3G1 | Turn Slope | 24(10deg/speed) | |||
| 3G2 | Turn Time | 30 sec | When taking turns, send a position report at most every 30 seconds. | ||
| 3H | PacketPath | 3H0 | Type | *New-N | |
| 3H1 | WIDE1-1 | On | |||
| 3H2 | Total Hops | 3 | |||
| 3I | Network | 3I0 | *APRS | ||
| 3J | WX Station | settings are irrelevant for standard APRS | |||
| 3K | Digipeat | 3K0 | Digipeat(MyCall) | OFF | Only use your radio as a digipeater when there is a special reason to do so. |
| 3L | UIcheck | settings are irrelevant for standard APRS | |||
| 3M | UIdigipeat | settings are irrelevant for standard APRS | |||
| 3N | UIflood | settings are irrelevant for standard APRS | |||
| 3O | UItrace | settings are irrelevant for standard APRS | |||
| 3P | User Phrase | settings are irrelevant for standard APRS | |||
| 3Q | Auto-Reply | 3Q0 | Reply | OFF | Your radio shouldn't reply to messages automatically. Read your messages and reply to them! |
| 3Q1 | Reply To | * | |||
| 3R | Reply MSG | 3R0 | Text | - | |
| 3S | Group Filter | 3S0 | Message | ALL,QST,CQ,KWD | |
| 3S1 | Bulletin (BLN) | Set up a filter for your special bulletins. | |||
| 3T | Sound | 3T0 | RX Beep | Mine | |
| 3T1 | TX Beep | OFF | |||
| 3T2 | Special Call | ||||
| 3U | Display | 3U0 | Display Area | Entire Always | Switch to something different if you don't like it. |
| 3U1 | Interrupt Time | 5 sec | |||
| 3U2 | Cursor Control | Followed | |||
| 3V | Units 1 | 3V0 | Speed, Distance | km/h, km | |
| 3V1 | Altitude, Rain | m, mm | |||
| 3V2 | Temperature | °C | |||
| 3W | Units 2 | 3W0 | Position | dd°mm,mm' | |
| 3W1 | Grid Format | Maidenhead Grid | Quite useful. | ||
| 3X | NAVITRA GP | settings are irrelevant for standard APRS | |||
| 3Y | NAVITRA MS | settings are irrelevant for standard APRS |
2 декабря 2011
8 сентября 2013
| 30... | Basic Set | 300 | My Callsign | DL8RCB-7 | Change to your callsign. Use SSID -7 to identify a human portable message capable station. |
| 302 | APRS Lock | ON | DM8TA-7 OFF Set this to on after having the right APRS frequency (144.800 for Europe). | ||
| 31... | Int. TNC1 | 310 | Data Band | A-Band | APRS will function on the A-Band |
| 32... | Int. TNC2 | 320 | DCD Sense | D or RxD Band | |
| 321 | TX delay | 150 ms | DM8TA-7 200 | ||
| 33... | COM Port | 330 | baud rate | 4800 | 331 input GPS, 332 output OFF |
| 34... | Waypoint | NMEA | 340 format , 341 length ,342 output | ||
| 35... | PC Port | Output | settings are irrelevant for standard APRS | ||
| 37... | Beacon Info | 370 | Speed | ON | Your speed is sent in position reports. Set to OFF if you drive excessively fast. |
| 38... | Comment | 381 | Position Comment | Enroute | Choose a comment describing your current activity. Don't use EMERGENCY! unless there is a real emergency! |
| 39 ?? | Status Text | 390 | Rate | OFF | Don't use a status text to keep your packets short. Use one if there is a special reason. |
| 3A... | QSY (FREQ) | 3A0 | QSY in status | OFF | Set to ON if you want to tell others on which VOICE frequency you are working on the B-Band. |
| 3B... | Pkt.Filter | 3B0 | Position Limit | OFF | Set to ON if you want to limit data you receive |
| 3B1 | Filter type | WX ??? | An ASTERIX (*) should be seen for all the options. Delete the ASTERIX with MHZ for the type of stations you do not want to display. | ||
| 3D | TX Beacon | 3D0 | Method | SmartBeaconing | DM8TA-7 Auto |
| 3E | Algorithm | 3E0 | Decay Algorithm | OFF | DM8TA-7 ON Doesn't make sense to set it to ON for low power portable. |
| 3E1 | Prop. Pathing | OFF | DM8TA-7 ON Doesn't make sense to set it to ON for low power portable. | ||
| 3F | SmartBcon1 | 3F0 | Low/High Speed | 5 - 70 km/h | |
| 3F1 | Slow Rate | 15 min | DM8TA-7 30 When not moving you will TX a postition report every 15 minutes. | ||
| 3F2 | Fast Rate | 90 sec | DM8TA-7 120 When moving above 50 km/h you will TX a postion report every 90 seconds | ||
| 3G1 | Turn Slope | 24(10deg/speed) | 26 | ||
| 3H2 | Total Hops | 3 | 2 | ||
| 3J | WX Station | OFF | settings are irrelevant for standard APRS | ||
| 3L | UIcheck | 46cek | settings are irrelevant for standard APRS | ||
| 3M | UIdigipeat | OFF | settings are irrelevant for standard APRS | ||
| 3N | UIflood | OFF | settings are irrelevant for standard APRS | ||
| 3O | UItrace | OFF | settings are irrelevant for standard APRS | ||
| 3P | User Phrase | OFF | settings are irrelevant for standard APRS | ||
| 3T | Sound | 3T0 | RX Beep | MINE | |
| 3T2 | Special Call | MINE | |||
| 3U1 | Interrupt Time | 5 sec | 10 | ||
| 3W | Units 2 | 3W0 | Position | dd°mm,mm' | dd mm ss s |
200 GPS normal,batt saver off, pc output off
